dingdowner
Greetings to all members,
As this is the best place to ask an electrical question, I know one of the older heads out there will have seen or used one of these some time in the past.
I have an old but still serviceable and very large Analog Multimeter Model K-1200P made by Kyoritsu.
I have been using it for basic electrical tests both AC and DC at home and in the car but would like to use its more extended functions other than just testing for power or continuity, as it has 6 other sockets apart from the Common(Black) and + (Red) sockets where test probes can be inserted. Does any one have any guidance on what these sockets can be used for? They are labelled- -10A and +1V close together, +50 MicroU/+250MV and +10A close together and Output and 1KV (AC/DC) close together. The range is 500MA (also used for transit) to 500V(1KV) on the left side of the rotary dial and 100MA to Rx10K on the right side of the rotary dial.
There is also a red Overload reset button, in case one is daft enough to set the scale below what one is actually measuring and it will pop up and need a press down to reset it. The meter can be used via a selector switch in -DC, +DC or AC mode and has a Zero Ohm knob and a needle adjuster screw to set the pointer to infinity if needed.
It is powered by an internal 9Volt battery.
I do hope one of the members can shed some light on the extended features offered by this very useful and obviously versatile test meter-Here's hoping!!!
Eric
Eric
