L.E.D Lamps Staying on | on ElectriciansForums
Discuss L.E.D Lamps Staying on in the Australia area at ElectriciansForums.net
G
gary174
Hi Everyone,
Wondered if anyone can help. I am a domestic installer and have recently changed some GU10 50watt lamps for some GU10 3.6watt L.E.D lamps. They seem to work perfectly except for the fact that they seem to continue glowing, very slightly once the power has been switched off. They have been fitted all day and are still on, i do realise that some L.E.D's can stay on for a little while after the switch has been turned off but these are staying on continually.
Can anyone spread some light on this for me.
Many thanks
Gary
This must almost be the most asked question of all!
Could be a few things.
First of all you have to understand that unlike resistive lighting LEDs get more efficienct the less current is going through them. Even 1 electron trickling past with pump out a photon.
magnetic induction from nearby circuits can cause a minute current to flow in the wires, this can slowly charge up a cap in the circuit until enough energy builds up for it to trigger for a fraction of a second.
if they are staying on for a long time after switch off, my money is on a slowly discharging smoothing cap.
Basically the electricity was always in the wires, but only the LEDs are efficient enough for you to see it!
To get rid of it, just stick a high value resistor across the terminals, this will stop to the electricity building up and allow the cap to discharge.
As I was first response, does this mean I get a thanks ;-)
There you go.... you got two out of it!! lol!!
Here's another query I have on l.e.d lamps , hopefully I won't have to start another thread on it, I have fitted some collingwood led lights in my plinths at home my other half says she sometimes sees them flash, I am yet to see it!! She is asking me why they do it , they are installed on the ring and I only have 1 ring in my house I am yet to start rewireing, any ideas
I am far from being an expert , but are there not two types of LED lights, being constant current (240V supply) and constant voltage (12V supply)? The additional resistor across the terminals would only work for one type and not the other. I stand to be corrected if misunderstanding.
Probably clearer to say, put high value across the switched live and neutral, to discharge the circuit.
It's in parallel with the lamps so has no effect on them.
Looking for a simple solution:-
If both the live and the neutral to these LED lamps is isolated at switchoff using a double pole switch, then I would be very surprised if they still glow!! If they still do, then they are probably living off capacitance from inside their own power packs but this should only be for a short period.
Double pole grid switches are great and they look like the normal single pole light switches.
Reply to L.E.D Lamps Staying on in the Australia area at ElectriciansForums.net
