H
HARRYSPADGE
Hi,
I have a question regarding the notification of electrical works to the LABC.
As I understand it from what I've read on here, if you are a member of an organisation such as Elecsa, NICEIC, etc, you are able to self-certify any work you carry out as a competent person. These organisations then notify the LABC for you - have I understood that correctly ?
If this is the case but you are not a member of one of these organisations, as a time-served and competent electrician, how do you guys who aren't members of an organisation go about certifying your work ?
Am I also to understand it correctly that some sparks see these organisation's as money making scams ?
Is it just a case of the LABC going by your qualifications to ascertain whether you are competent or not ?
Thanks in advance.
Thanks in advance.
