Labels for CU | on ElectriciansForums
Discuss Labels for CU in the Australia area at ElectriciansForums.net
L
lecstar
Whats the best way most convenient and cost effective way of labeling each way in cu.
I use a Brother label machine and number each way, then stick a ciruit ID sticker to the CU or next to it with what each circuit is for.
Makes life easier for those with poor eyesight as your not trying to make out the tiny little sticker that come with most CUs.
Thanks for the reply, my eyesight is going fast too, need something I can see and use looking through my inch thick sorry 25.4mm thick glasses.
Which machine part number and what size labels do you use?
sorry lecstar for not replying , i use the brother p touch cracking machine use a 12 mm tape with a bold font looks quite good but i lable the ways and DB no in multiple DB's , as well as any info needed IE lighting circuits have no cpc etc etc
Reply to Labels for CU in the Australia area at ElectriciansForums.net
No it is not implying it is safe, it is stating what the recommended date for the next inspection is. The next inspection date sticker doesn't...
davesparks
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
