Forty_Two
North England (not London) . . . What is a FAIR daily rate (just labour no materials) for an electrician, an electrician qualified to remove and replace a simple domestic consumer unit test and certify that work?
When I use the word FAIR I mean . . . plasterers, brick layers, plumbers, car mechanics etc., etc, all of whom will have (what you and I believe) is a FAIR daily labour rate, and some trades will be more than others . . . . what do you believe that should be for a domestic electrician?
Are the rates in the below link accurate?
Electrician rates near you for 2024
See how much local Electrician charge per hour & day instantly online (no need to phone around). Get quotes for your jobs and save money.
www.hamuch.com
