Ladder choice | on ElectriciansForums
Discuss Ladder choice in the UK Electrical Forum area at ElectriciansForums.net
I was pointed to that site for their ladders, by other members of this very forum.
Never go them in the end though, bought others instead, as for the same size of ladder, you go slightly more height
Zarges are king of steps, as far as I'm concerned, I've trusted my neck to them on many an occasion! But, you pay for the privilege.
used to get zarges hired for me when i worked at norland managed services from hss and i decided to buy myself a set from wickes, alas they don't do the same job, the are lighter and just as stable but they dont go as high if i lived life again i would have bought zarges,
ladders are for life,
unless you leave them lying about on site
or let the builders borrow them
Reply to Ladder choice in the UK Electrical Forum area at ElectriciansForums.net
I'm dealing with an Omega VSJ843RSG vertical juicer that appears to be dead. The mains switch and fuses are all good. I can't find a circuit...
Useful to know. In my case there will be 150x150mm trunking at top/bottom and almost certainly I will be using tri-rated cable, probably 70mm...
