ladder m8rix | on ElectriciansForums
Discuss ladder m8rix in the UK Electrical Forum area at ElectriciansForums.net
The company I use to work for insisted we used them and didspot checks to make sure we were using them
Personally I didn't use it because I never felt safe on it.
It's basically a plastic board with the metal strapping plate they use to hold together house roofing joists.
The company insited that they were trailed and tested and would never ever slip but I never felt safe with the ladders on it. Much prefer to put the ladders on hard ground.
Certainly don't use them on polished wood or decroative floors as the spikes will ruin it.
Ok on grass as a flat surface as long as the ground is hard enough otherwise the board slopes
The sales reps came into the company to do training and showed ladders at all angles that didn't slip but it certainly never made me feel any safer if anything I felt worse using it. That's just my personal opinion though
Thanks for your message, why did it make you feel worse? Was the product poorly made?
Wasn't poorly made no, the ones I had to use did feel a bit home made in the shed If you see what I mean. This was 6 years ago so things have probably changed.
I get the physics behind it i.e. Lots of small surface areas creates bigger resistance to the floor.
I personally just never felt safe on it felt like it would slide. I much rather have the rubber feet of the ladders on the floor
Oh ok, I get what you mean. Cheers
I've actually bought one a few weeks ago and have just tried it out for the first time this week wiring high level lights in a barn. So far only tried it out on concrete floor but I like it. It might just be a trick of the mind be it seems secure and I'll continue using it.
If I have a horrible accident using them I'll be sure to let you know!
Just an update. I ended up buying one. It seems well built and looks the part, haven't actually used it yet though :) I'll let you know what I think once I've tried it out.
Reply to ladder m8rix in the UK Electrical Forum area at ElectriciansForums.net
Some spectacular ladder incidents from teleshopping channels. Think I may have posted a few before, but this is a particular favourite.
nicebutdim
N
Haha! Normally I would sweat just reading those posts! I'm not that steady on my feet when I'm standing on the ground, so ladders are hateful for...
