Lamona Range Cooker Overheating After New Elements/Thermostat | on ElectriciansForums
Discuss Lamona Range Cooker Overheating After New Elements/Thermostat in the Electrical Appliances Forum area at ElectriciansForums.net
UK
Hi, hoping someone can help me, have a Lamona HJA5110 range cooker, previously had a new element fitted on the RHS oven and it was overheating, so had a new thermostat fitted, still overheating, so never used it. So recently fitted new elements to both sides (LHS and RHS) with a new thermostat on the RHS (left hand one was fine), problem is now both ovens are overheating to approx 280 and 300 degrees. Any ideas? Advice? would be most welcome, thank you :)
check that the stats operate correctly (meter)set on VAC) and reassess your wiring.
Reply to Lamona Range Cooker Overheating After New Elements/Thermostat in the Electrical Appliances Forum area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
I fitted a Mem MR30 Pod and MCB, about ÂŁ75 for both.
