landlord card meters | on ElectriciansForums
Discuss landlord card meters in the Australia area at ElectriciansForums.net
G
garyinderby
Hi Guys and Girls
Has anyone fitted landlords card meters? could do with some advice on how to fit them as not had the pleasure yet. also what would you charge per meter?
Look forward to your replies
Gary:eek:
lemon squesy bud, live in. netral in. neutral out. live out. May have auxillary terminations for night rate.
Go onto web site Stephen P. Wales and there is a clear diagram. Enough slack in the cable is always a problem, however, pull main cable back from board install into meter, then new length from meter to board. Basically they are just like a normal house meter.
about an hour per meter, scrw to wall and put wires in, etc, programming is fun. If economy seven is involved, get the right meter so that the tennant doesnt have to wait untill midnight before the meter becomes live so they can feed it with money/cards.
You will also need an Earth block as these meters dont have any kind of Earth rail or terminal.;)
Reply to landlord card meters in the Australia area at ElectriciansForums.net
My older card has it but my newer card doesn’t
Thanks for the reply littlespark. Yes the works have been carried out. Surely it is fraudulent because basically the document is Not...
