Landlord supply help! | on ElectriciansForums
Discuss Landlord supply help! in the UK Electrical Forum area at ElectriciansForums.net
M
mike2790
Hello everyone,
I got a call last night from a bloke asking me what he can do regarding a landlord supply. He is the landlord himself and told me he has a longstanding arrangement with a tennant whereby the fire detection is all supplied via her CU. He would simply compensate her by paying her a set amount of money to her eaither every month/week (i forget which). The landlord tole me he has since had an unrelated visit from the dno who noticed this and have told him it is illegal to do this and he should have a landlord supply which feeds accessories, fire protection and lighting in all communal areas. Is this right of them to say that it is illegal if the landlord and tennant have this agreement as the electricity is all getting paid for in the end and the tennant is getting overcompensated for supplying the electricity for the fire detection?
As of yet i havnt been to the flat to look at the actual set up. All i know is the above and that there is 3 flats.
Just want a bit of advice before i go to the job and give out wrong information.
Also if it is illegal and i do end up having to install a seperate landlord meter to feed communal circuits, can anybody recommend a decent place to pick them up?
thanks in advance,
Michael.
Hello mate,
Regarding the landlord supply i think this is correct the landlord supply must control emergency lighting, fire alarm system, security system. I think this is due to the tennant being able to isolate the safety items which feed the flats. I'm about 90% sure I remember discussing this with 1 of my follow colleagues.
thanks for the reply, eollou88. that makes sense what you said, i'll have to go and have a look at whats what. do you happen to know if im allowed to fit a new meter to feed the safety circuits or would that be upto the dno? i have experience in installing and altering metering arrangements etc but just dont know if this is a matter for an electrician ie. me or the dno. thanks again
i`v had a similar one recently...at a mill in bradford....
theres a switchroom......but all the communal lighting and emergencys were pulled of ov one of the panels on the third floor (tennant).....
anyway the mill belongs to a friend of mine.....
i have told him he needs a seperate supply for these services coming direct from the switchroom....
The dno isn't responsible for the metering equipment so I don't know why they feel the need to raise the point.
And if it was the supplier then their only responsible up to the tails leaving the meter.
I can only think if the tennant doesn't pay the bill and the fuse is pulled there goes all the safety circuits.
I am surprised that the dno would either notice this was the case or know the legislation behind it. Surely it is a consumer situation, allthey usually care about is putting the prices up...
Reply to Landlord supply help! in the UK Electrical Forum area at ElectriciansForums.net
Happens on every job of ours, houses are usually empty for a year or so and they are always ÂŁ300-ÂŁ400 in debt mostly due to the standing charge...
I would think that if they are apartments, and not something like uni halls with private bedroom and communal facilities, then each one would be...
