C
callum44
Hi,
installing some sharp panels in a few days in a configuration whereby they will all be in a horizontal line and in landscape format. i was planning on using hanger bolts with the rails also running horizontally. I know your not meant to use clamps on the short sides of the panels so wandering if anyone has installed the panels with the long sides resting on the rails then using 4 end clamps per panel. i've seen sharp allow you to do this but havent seen it much elsewhere.
Callum
Callum
