C
colincase
I have decided to install a large PV system in my paddock next to my garden.
I am aiming at 9.99kWp to make the best of FIT break points. Around 50 to 55 panels, by the rough sums I have done. All in one long row of about 45m, mounted at 30/40 degrees and facing due South. Will hopefully net about ÂŁ3,500 pa in FITs, savings and export, with a capital cost of around ÂŁ28k. Space is NOT at a premium - relatively low efficiency panels are OK so long as they are cost-effective. This appears to be a fairly uncommon task for some of the potential installers I have spoken to.
And it raises a few questions:-
My house has only single-phase. This seems to be a problem at this power. My neighbour is definitely on a different phase - not sure about the next neighbour. How can I find out who is on which phase? And am I allowed to feed their homes with the appropriate phase? Can I charge them, say 8p per unit (between the 3.1 and 13p for export and purchase prices) And still get FITs and still export any excess on each phase? Or is there a better solution?
How do I choose a supplier for this type of system? Does anyone specialise in this size and field-mount?
Can I mount the inverter and meters in the field with the array? There doesn't seem much point bringing the DC to my house, only to have to re-distribute. And distribution losses should be downstream of the meter (preferably - obviously)
Impressed by the quality of helpful replies on this site, so I hope you can help in this case.
Thanks, Colin
Thanks, Colin
