P
powerelec
any advise on how chase the lat and plaster walls and get a fixing for a plasterboard box or metal box
Discuss lat and plaster walls in the Australia area at ElectriciansForums.net
exactly what truckster says. do not chase lath and plaster, you'll destroy it's strength. treat it as a studded wall. what i try and do is cut for the box on a vertical 3x2 timber, chip it out, and fix metal box to timber.
If possible don't chase them, you can usually feed the cable down behind the lathes. You can sometimes cut a neat hole to fix a plasterboard box if the plaster isnt too thick or screw a batten across the hole and fix a metal box to that.
Yep like that word sometimes like sometims the wall falls to bits when you try to cut into in and in the flats where I stay I cannot understand why people fit un-hooded halogen spots into a lathe and plaster ceiling because as far as I am concerned Lathe is the best fire tinder in the world
Had one of these last week......... ideally baton in and fix metal knock out box to this to this.
But if not possible : Fein cut ---> fast fix box ---> squirt of foam ---> lovely
never been able to get a squirt of foam out of the tin without it then drying up in the nozzle and having to chuck the rest of the tin.
Reply to lat and plaster walls in the Australia area at ElectriciansForums.net
