Lath and plaster ceilings | on ElectriciansForums
Discuss Lath and plaster ceilings in the UK Electrical Forum area at ElectriciansForums.net
Glasgow
Can you normally fish from room to room above a lath and plaster ceiling? Ie if you’re trying to get a cable between all detectors but there’s no access above can you normally fish between rooms?
Yeah that’s what I’m meaning, can you normally rod through from say the hall into the living room above the ceiling
I don't think there's much difference between a plaster board ceinling and lathe and plaster with regards using a cable rod from below. The rod will go up from below, hit the floorboards and travel along.
If however you were working from above, the rod would then hit the lathe and can be a pain on longer runs.
You may well find a few nothes you have to get past though. Ie more holes in the ceiling.
Edit... little spark has beaten me to it!
Reply to Lath and plaster ceilings in the UK Electrical Forum area at ElectriciansForums.net
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
L
Bathroom leak disaster- wet room the culprit? Hi there, Several days ago the plaster board of my living room ceiling collapsed, as a result of a...
Lisa2021
L
