Discuss Lead Gas Pipe in the Australia area at ElectriciansForums.net
You either need a spring clamp, or get the DNO in.
Why would the DNO want to get involved with a gas pipe?
It is Lead all the way to the entry point into the house and is then lost until it exists at the boiler(now copper). l really need to bond it at the Gas supply. Thanks for your help. I will check with the wholesaler. If anyone sees a link to something suitable I would really appreciate it. Fingers crossed
An old gas lead pipe is certainly not as thick walled as the old lead water pipes, simply because of the pressure both services work at.
What I have done in the past is get a piece of perhaps 2 or 3 inches long, say a 25mm copper pipe, or a size near to the lead one, and cut it in half, place the 2 pieces around the lead pipe and then fitted a BS 951 clamp over the copper part.
Reply to Lead Gas Pipe in the Australia area at ElectriciansForums.net
