lead pipe | on ElectriciansForums
Discuss lead pipe in the Australia area at ElectriciansForums.net
The last lead gas pipe I ever saw was the one I flaming well cut through!!!!
I had a battery circular saw and was cutting a floorboard for access, I'd set the depth and everything but some freak had actually routed the underside of the floorboard to make it sit flat!!!!!!!!:eek:
To this day I still dont know how I didn't take out half the street.
Apologies for meandering off thread a little.
You can`t bond to lead gas or water pipe - lead is too soft and "creeps" under load, the clip loosens and the possible arcing (in the even of a fault) could lead to a gas leak and explosion (or so the theory goes?).
You must either replace the lead pipe or a section of it to enable a secure connection for your bonding conductor.
the person I am doing the job for is changing the gas pipe to copper (so no problems there) but she wont pay to change the lead water pipe. I need this job be be perfect as I will show the NIC to hopefully be enrolled. should I carefully clamp a ec15 near to the stop cock or is it with in regs to bond at the kitchen where lead changes to copper
I think its when you connect copper to lead that the problems occur not the other way round?
I dont see any reason why you cannot bond on the closest copper pipe.
If the assessor asks why you didnt bond on the lead, then you have some good answers for him!
Reply to lead pipe in the Australia area at ElectriciansForums.net
Capped gas pipe begging oven Hi all. Hope you are well. So I fitted a new induction hob today for my father and whilst the old hob was off I saw...
Steveuk
T
Is this bend in a PEX pipe too much? Hi, I by chance discovered that amongst a bunch of copper pipes, I have a PEX pipe that runs through a void...
techweb
T
