I want to learn how AC works and I have no idea what I should use as an AC source since I never used one.I only know of inverters but that's not really helping me in understanding RLC circuits....Are AC sources real?Are they batteries?I'm new in this and I can't think of a device or something that allows me to learn how the voltage and current change from negative to positive in the AC.Also I don't want sockets as an example.
There are AC sources just about everywhere.
If you want a safe supply for testing purposes, then you should obtain an isolated power supply.
These devices use a 1 to 1 transformer to isolate the supply from the mains.
That's a transformer.What does this have to do with what I want?Are you saying that you use a transformer for an inverter?I don't understand what you are saying.I wanted to know if it is possible to change a DC 1,5v baterry with a transformer to an AC voltage of 220-230 v.
Can you make a circuit for an isolated power supply as you suggested?I searched google and found some circuits.
Here is an image of an isolated power supply:
Upload the image directly to the thread - https://Upload the image directly to the thread.com/a/acYOcDw
AC alternates because it is produced by rotating magnets.
When the magnet is pointing up, the AC is positive, when the magnet is pointing down, the AC is negative.
AC can come from invertors, but mostly it comes from alternators
NOT generators, generators produce DC, alternators produce AC.
Sounds to me like you are yet to get your head around basic theory,
So I suggest you do just that,read up on basic theory.
When you have come back and ask questions that you can then get your head around.
So So little grass hopper.
Sonny, you are trying to run here before you can walk, you need to go to basics and learn about the subject, there are no short cuts to understanding it so you need to learn the basics, AC passes through the zero volts and reverses DC does not but can have a waveform in its own right, perfect DC is a straight line on a graph.
If your laptop is plugged in to the mains then you are using AC.
When you where 11 and hidden under the duvet knocking one off to dodgy magazines with a torch that was DC current in use.
I should have been a teacher at electrikery school......
No need to get him into friction and static.....
Buy a borrow a cheap oscilloscope ,and a cycle dynamo !
("You tube" could actually save you from buying a single thing.)
Then the peak ,-vs- rms lies begin ...
(Maths s why square something -to remove its polarity !-)
Romania
Business Name
none
Learn AC current and voltage by every electric machine or electronic circuit you know
Electrician Talk Forum
sonny,
static zap,
