Spark2be
Hi,
I am currently studying the 17th ed and I was hoping that some experienced sparks who have passed this exam could give me some advice of how best to revise. At the moment I am answering questions from the NIC learning guide and also pass papers that my tutor gives me on a weekly basis.
What helped you pass this exam??
Cheers
Nothing more than you are doing ^^^^^^ along with making yourself familiar with the BGB, its all about knowing your way around the book itself and understanding it of course.
Learn to navigate the book. Stick tabs on the side of pages. This will save you valuable time during the exam. In the exam, answer the quick questions and question you know first, to build up a points base then return to the long winded one and the ones where you ain't got a scooby.
The NICEIC learning guides for the 2382 regs , and 2392 courses are excellent in my view.
I'd look forward to 2396 if they ever get round to producing it.
Spotting the key words in the questions to look up in the index.
I've had a few where I've only found the answer on the 3rd or 4th attempt. (that starts getting annoying!)
Make yourself familiar with the layout.
Part 1,2,3 and so on, until you can recite them, i.e part 4 is protection, part 5 is selection and erection etc etc. Stick some tabs in the book at the first page of each part. Dont write in your regs book, and dont highlight text. Once upon a time you could, but these days you have to have a clean copy of the regs for the exam. Tabs without text, post it notes without text and folded over page corners are acceptable.
A lot of questions come from lists and tables, a very good page to make a note of is the table of tables.
It is highly unlikely that you will get any calculations of any great difficulty, but ohms law calcs will crop up.
You may also be asked from a choice of answers, which one of the given calculations is correct, so make sure you can read them, and in particular symbols such as > and <.
I agree the NIC learner guide is excellent, and i use it on my courses.
Dont beat yourself up about revision, there isnt much you can do, the course will put you right, and the pass rate is high. You will get 60 questions, and 120 minutes to answer them in, so thats 2 mins per question. there isn't much too involved that you can do in 2 minutes, so the questions are usually fact related, rather than having to do complex maths.
When a table or chart is explained to you, make sure you understand it, there is nothing more annoying than getting the correct table, and getting the wrong answer.
I have put 208 people of all abilities and ages through it this year, and 207 have passed. The one who didnt had no electrical experience, but his boss told him he had to do it.
Cheers.............Howard
If that isn't a clear indication of how easy it is, I don't know what is!!!
Yep, I taught the 2381,2382 for several years and the last time i took the exam i got a question wrong, not as bright as i thought ! but then I did only take 25 mins.
Its a bit of ...do as i say and not as I do -
1/ use the full 2 hours,
2/ do the questions that you know the answers to first
3/ and flag up the ones you are not sure about or haven't a clue
4/ Don't waste time on questions you haven't got a clue about, just flag them up
5/ Its a confidence building exercise as you go through the questions
6/ Get your regs book out and answer each question you are not sure about
7/ Leave the questions where you have no idea about until last
8/ you have 2 mins per question so there will be a % that you can answer quite quickly and then store up the minutes for the questions where you will have to work hard searching for the answers
9/ The answer is often in the question so you will be looking for the precise phrase
10/ Oh yes don't forget to read the question, some are phrased as negatives.
Thanks everyone, some really good advice there. As long as I think I'm on the right path I will just keep plugging away. Nice one, thanks very much.
Listen, study and understand fully. Once you've passed, please learn how to be an experienced electrician before being in a position to put yourself or others at risk.
The 17th is not about learning the book from cover to cover but more about learning how to use the book.
Hope this helps.
Learning the regs advice please
Spark2be,
jarmez,
TrueNAS JBOD Storage Server
