LED Bulbs - Help Required! | on ElectriciansForums
Discuss LED Bulbs - Help Required! in the Australia area at ElectriciansForums.net
Damian1977
Hi,
I recently invested in a set of MR-16 LED bulbs that I picked up from Ryness. The power the old halogen bulbs was using was getting ridiculous, as I have a total of 10 throughout the house.
These bulbs fit conveniently to the existing connection and transformer on each light fitting. All work fine, with the exception of one, in the bathroom, which flickers like a strobe light. The only difference I can see with this particular light fitting is it is connected to the same power cabling as the extractor fan. The light is sometimes constant, however it can flicker when the fan is switched both on and off.
I have tried changing the transformer, the light bulb and tested both in other light fittings around the house. The bulb only flickers at this one location.
Does anyone have any idea how this can be fixed?
Thanks! :)
Reply to LED Bulbs - Help Required! in the Australia area at ElectriciansForums.net
Thanks for you response, that makes more sense LEDs do produce less heat. I think i read somewhere that LEDs are more sensitive to heat, as in...
For my hapeneth and learnt from hard recent experience, the term LED transformer and driver tend to be used interchangeably, when they are...
