Hi there,
Just installed 8 GU10 down lighters each having a 4w Philips dimmable LED lamp. Installed a Varilight V-PRO 2 gang touch control LED dimmer (min load 10w) (trailing edge)
All was working great until yesterday. Been again to look and cant seem to figure out what is wrong.
1 gang does 4 spots....these work great.
2 gang does the other 4 spots but when turned on the lamps initially flicker, dim up and down, then switch off completley???
Faulty dimmer?
Cant think what else it could be?
Faulty dimmer?
