Can any one help?
Just been to a customers house and in a loft extension there are 6x LED downlights (cob). The last downlight in the circuit seemed to be cutting out when the dimmer was at the minimum so I replaced the standard LED for a varilight dimmer so the minimum could be adjusted slightly. Even after this, when the dimmer is switched off, adjusted to minimum and switched back on that one downlight in the circuit seems to stay off. Any ideas? Maybe volt drop?
