LED Downlight Removal | on ElectriciansForums
Discuss LED Downlight Removal in the UK Electrical Forum area at ElectriciansForums.net
Cornwall
Hi all,
I have 15 downlights in the kitchen but need to remove one due to getting rid of an aga and needing to install a new cooker and extractor hood - the hood is going where one of the downlights is located.
I've replaced plenty of these over the years, but wanted to check the best way of co9mpletely removing it.
Is it simply a case of disconnecting the light, and using a terminal block to isolate the wiring for that one light?
Many thanks
Actually just found a 5amp junction box in the garage. Disconnected the light and transformer and connected the wires back up in the junction box. Tested everything and it’s working fine. Good to go??
Have you waited an hour with the lights on and had a good sniff around for burning ?
Reply to LED Downlight Removal in the UK Electrical Forum area at ElectriciansForums.net
I'd start by doing the usual supply impedance tests followed by N-E voltage with the installation under some load. Also visually inspect and...
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
