LED downlights | on ElectriciansForums
Discuss LED downlights in the Australia area at ElectriciansForums.net
O
Octopus
Being lazy - suggestions please for low cost "good" LED downlights.
For use in a kitchen and dining room
Thanks all!!
I would avoid the lamps where theyve stuch as many low power leds in, some have upto 48 leds!
ive used some 4w phillips which are nearly comparable with a 50w halogen, contained 3 x 1w high power leds with a wide viewing angle and opticle lense to improve the beam. they cost around 5-10ÂŁ
i personaly think warm white for a house, alot of people buy good lamps but get cool white and the light is harsh and not very good a showing colours!
led technology gets better each day, ive seen a prototype range of t5 tubes which have clever opticles and are actully brighter then flourescents!
I fit halers which is just collingwood really. roughly 35 quid a fitting no bulbs to change and a 7 year guarantee if you register them 50w equivalent. also have an aurora sample which just been given which are very nice feels bit more robust than the halers. i personally dont bother with the bulbs dont forget your loft caps :)
Bulbs grow in the ground lamps go in you fittings
Are these the 7 watt Halers you use? How do they compare with a standard 50 watt hologen. Looking to complete lighting for a kitchen/diner at the minute and they are willing to go down the route of high quality fittings rather than using standard GU10 fittings and replacing lamps with LEDs.
Also a lot of the retro fit high powered LED lamps are to long for a standard fitting, so stick out the end, which is rubbish!
Have used JCC 7 Watt fire rated LED fittings recently on two jobs, and was impressed by the light output, I`d say brighter than a GU10, no smoke hoods to fit and a 10 year (domestic) guarantee, and about the same price as Halers.
Only concern is non-changeable lamps again.
Reply to LED downlights in the Australia area at ElectriciansForums.net
seen a couple of your posts now and IMO you are trying to save money by doing the design and install yourself even though you have no...
Depending on the size of the downlight hole you may be able to fit a circular dry lining box, these have standard fixing spacings for installing a...
