LED downlights | on ElectriciansForums
Discuss LED downlights in the Australia area at ElectriciansForums.net
L
lionelmcc
Hello folks
does anyone know about fitting LED downlights in an insulated ceiling?
I know they dont generate much heat but what about the DC tranny?
Also can I power 3x3 Leds from one 11w tranny via a jb, if so what cable on the DC side?
L
We just had the exact same problem today, and the surveyer had absolutely no problem with us using led fittings in a dormer roof, we had no room hardly, and virtualy thats all he would let us use.
What wattage are your led fittings you want to run off an 11w trany,
.5 a bit small mate as you probably know as the volts go down the amps go up, we would use 1.oomm or 1.5 if the connectors lend the selfs to it, cause mostly these days the connectors are foreign rubbish and the cables don,t go in, if it will take the 1.5 use that.
Reply to LED downlights in the Australia area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
