LED Driver | on ElectriciansForums
Discuss LED Driver in the Electrical Tools and Products area at ElectriciansForums.net
T
tim_irons
Hi All
I have never posted before but i need some advice, I need to source a LED Driver my wholesaler says that it cant find it the driver in question is
AC Adaptor
24v dc 2 amp
the above is what it says on the driver it self the driver is used on a led round feature in a retail unit
Can anyone help on this i have never really dealt with LED's before
if it's a straightforward 214V d.c. adapter, then a 24V psu for CCTV would do the job. however, unless you get the exact replacement as recommended by the LED manufacturer, you risk blowing the LEDs.
Reply to LED Driver in the Electrical Tools and Products area at ElectriciansForums.net
The company Liteplan do replacement modules: Liteplan – The UK's largest emergency lighting component supplier. - https://www.liteplan.com/ This...
Assuming the electrician checked the new driver was capable of supplying current (in other words it provided an output voltage and curent when...
