led fittings and dimmers | on ElectriciansForums
Discuss led fittings and dimmers in the UK Electrical Forum area at ElectriciansForums.net
H
hodgey1972
Gents, i have an issue to resolve, I have been asked to replace some non led grid dimmer switches, that have been controlling a mixture of led and non led fittings, all installed in 2013.
My questions are
1. the dimmers have been coping up to now ,id of thought they would of failed instantly?
2. Did manufacturers at any point indicate it was ok to dim led fitting with 'normal dimmers?
3. Can i dim capsule and led lights on same dimmers?
Where can i get more info on dimming led fittings in general/
My questions are
Normally from the manufacturers of the led lamps that have been installed.
Reply to led fittings and dimmers in the UK Electrical Forum area at ElectriciansForums.net
Thanks davesparks. Looking at the diagram on the driver that's what I interpreted too, but I heard somewhere that the DALI system doesn't like...
I have a led panel that i want to dim. It is dimmable but without a dimmable driver. I have a dimmer module and a dimmer switch as shown in the...
