R
RobMS88
Hi,
I have recently been having a fault with my LED flood light in my garden. It works OK for about 3 minutes and then flickers like a strobe. If you turn it off for a period, then turn it back on again it works for 3 minutes again and then again flickers like a strobe. I have had these lights for about a year and only used them a handful of times so am dissapointed this has happened. I have attached some images of the light and its manufactuer label. Can I fix this myself? Is it the chip or a capcitor or something inside?
I was wondering if someone could tell me if these ones are any good because they were chosen by the electrician who installed the wiring and what manufacurer people reccomend I go for? I was shocked to see you can buy 50 watt floods LED for ~£20 (what are you going to get for that money) and thought they may go wrong as most likely cheap foreign rubbish chips etc.
The magazine I am looking at (CPC) has choices from Pro Elec, Manhatten or Eterna. Price is not so much of an issue if they work for a decent time 50000 hours, but replacing cheap lights every year for 20 pounds a pop adds up.
