Led floodlights | on ElectriciansForums
Discuss Led floodlights in the UK Electrical Forum area at ElectriciansForums.net
TAZ
Hertfordshire
Good evening everyone. Can anyone recommend good quality PIR led flood lights to replace a couple of old 500w pir halogens The wholesaler i use had some on display on the counter. I will admit they were a quality fitting but came with a quality price ( approx £ 149 + vat I am not looking for top of the range but something reliable & has the usual adjustments etc & give roughly the same kind of light output & colour temp as the old halogens, or if there is something else on the market that you might know would serve the same purpose. Kind regards TAZ
This is the one I've just stuck up, maybe a little overpowered at 180w ;)
[ElectriciansForums.net] Led  floodlights
try timeguard twin 8 watt ive put a few up dont rust out, not as bright but massive saving on power
just another one is a twin spot that poofix do using G9 lamps i fitted two at home been going for over three years plus and easy access to the lamp and thay dont rust ( I live by the sea and some fittings dont last more than a week )
all depends on location and application too..
its Sunday and the suns out must be dreaming might wash the van it was red last year ha ha..
I just installed 30W Single SMD LED floods with PIRs on a house, do the business well. At a guess their output was equivalent to 200W each which lets face it is more than adequate for most situations. They came in at £45 + VAT each and seemed decent quality. I`ll check the invoices tomorrow and see what make they were
I have fitted lots of led floods many of the fittings are the same just a different brand on the box. It is a good idea to shop around as I found the same lights £30 cheaper just a different name on the box.
Try ledhut.co.uk
Reply to Led floodlights in the UK Electrical Forum area at ElectriciansForums.net
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
Hello - Did you get your problem sorted?
