[FONT=&]Hello All,[/FONT]
[FONT=&]A theatre that I am involved with is currently under new management and they know that I have electrical 'skills' which I am more than happy to help them out but wanted another couple of opinions on this particular matter. [/FONT]
[FONT=&]The stage area that was added some 50 years after the building was built has no general lighting. It has 3 5ft fluorescent lights that are low wattage for when there is a show so not to bleed onto stage during a black out but still allow people to walk around etc. That's fine for during show but when we are rigging the gear on lighting bars that are 5-6m above stage level then there is no light and is difficult to see what you are doing. [/FONT]
[FONT=&]So the solution that a couple of us have come up with is to mount 6 led flood's around the 3 walls on the stage.[/FONT]
[FONT=&]Approximate stage dimensions (in meter's) are 14 wide. 10 deep. and 20 to peak of apex ceiling. 15 to edge of ceiling/top of walls on left and right. [/FONT]
[FONT=&]The walls are painted in black from floor level to 10m then original 'cream' to top of wall and ceiling. [/FONT]
[FONT=&]Now the plan was to mount 2 led floods on each wall facing vertically to the top of the stage, with the hope that the light will 'bounce' off and illuminate the rest of the stage. We decided against mounting them directly above as the led chip would be too blinding looking into it whilst up the ladder! [/FONT]
[FONT=&]So with the ideal amount of 6 floods, what would people think the best wattage is, 20,30 or 50's?[/FONT]
[FONT=&]For now they will be installed with flex and run to plug tops for a temporary solution until I can find where the conduit run is for the existing 'show' lights and tap a P+N from there![/FONT]
[FONT=&]Thanks In Advance![/FONT]
[FONT=&]Sam[/FONT]
[FONT=&]Sam[/FONT]
