I needed a head torch and read on here about LED Lensers and others at £30+. Which I was a little reluctant to spend considering the limited use it will get. I did consider the cheap £5-10 ones from Screwfix, DIY shops but thought something a little brighter and rechargeable would be better.
Anyway I decided to do a bit of research and came up with a brand called Cree. The actually make the LEDs not the head torches. They have full technical spec online and make a variety of LEDs.
So I bought a Zoomable 300 LM CREE Q5 LED Headlamp Torch from ebay £16 delivered. Came today with 2 x 3.7v 2400mAh Lithium Ion batteries and a charger (american plug with adapter). It only needs 1 battery so other is a spare. The battery is charged while in the headtorch. They also make them to take 3AAA batteries but judging by the brightness AAA batteries wouldn't last long!
WOW it's amazing. Has 2 brightness settings plus a flashing mode that are sequentially accessed by pressing same button on front! It is amazingly bright and can go from spotlight to floodlight beam. The battery is located at the rear so it seems well balanced on my head.
It is stated at 300lumens brightness and boy is it bright! It can be angled down but only in steps although they seem to be fine for close up or arms length work.
The one really silly thing is that when ever a battery is in it a little red led on the battery box flashes once every 3 seconds!!!! You can only stop it by opening battery box up and sliding battery back and down a little.
If you want to look for one search for 'Cree Q5 headtorch' although there are other Cree Led headtorches that may be brighter.
Anyway for £16 I am very happy. Hence my mini review.
