LED ight string and Voltage Detector | on ElectriciansForums
Discuss LED ight string and Voltage Detector in the UK Electrical Forum area at ElectriciansForums.net
Ankmorpork
Hi All,
I have a broken LED light string (I've two actually, one embedded in an Xmas tree and one standalone) . It seems these are wired in series so I presume that one or more LEDs are U/S. The challenge is finding the broken LED(s) and then what to do with them.
I was prpposing to simply work down the string seeing where there stopped being a voltage (and asuming the immediately prior LED was broken). But that will be tedious. The LEDs contacts are wrapped in tape so I was thinking of a non-contact voltage detector.
Are there any cheap non-contact voltage detectors that will work with LEDs? I think this string has DC as there is a PCB with 4 diodes on it (looks a bit like a recitfie) at the start of the string r and I thought non-contact voltage detectors were a bit iffy with DC?.
Assuming I can find the LED, I guess I just replace it with similar or perhaps with a simple resistor (and ignore that light). What is the correct resistance?
Thanks for an thoughts
Hi All,
How long is a piece of string?
There's numerous configurations of fairylights, some have individual 'driver' circuits contained in each lamp some have a common driver at the beginning of the string, some are arranged with groups of lamps in series and the several groups are arranged in parallel to achieve a certain voltage at each lamp. Without breaching the insulation on the wires between the lamps or cutting them entirely I don't see how you're going to establish which lamp is the culprit then you're going to have to solder and heatshrink to repair afterwards. There could be multiple lamps faulty as well if it was surge damage.
I'm inclined to agree it's one of those jobs where you're better just replacing with a brand new item.
Clearly some of the contributors have been down the pub - lucky so -and-sos!!
I dont mind throwing away the individual string but those integrated with the tree are more expensive to replace. (c. £80 retail)
As to 'no user serviceale parts inside' - bit like "sell by dates" IMHO - Only there to get you to dispose and buy more..
Anyway, can I take it (*from the absence of replies) that there is no such thing as a cheap DC voltage detector?
Twice as long as it is when it is folded in half mate :biggrin:
not quite. there's a formula:
L1 = L2(2∏Γ-s)/p
where L1 is the half length, L2 is the full length, r is the radius of the bend when you fold it in half, s is the stretchability constant for that particular type of string, and p is what i'm taking with this post.
You can fault find by prodding a fine needle through the insulation into the core and clipping your meter lead to it. If it's fine enough, the insulation will close up when you pull the needle out.
I would only do this if I was sure that the light string was SELV (ie separated from the mains supply).
L1 = L2(2∏Γ-s)/p
  • [ElectriciansForums.net] LED ight string and Voltage Detector
Reply to LED ight string and Voltage Detector in the UK Electrical Forum area at ElectriciansForums.net
