This may seem a daft question, but can you replace standard 50w GU10 halogen lamps with GU10 LED lamps? I’ve got a customer who wants the lamps changed in his fire rated down lighters. But during a recent visit to the wholeseller, I was told that I could only use LED down lights with LED lamps for correct heat dissipation.
I can’t see the logic behind this as there is a lot more heat generated from a Halogen GU10 lamp than a LED GU10 lamp. Besides the LED lamps are designed to fit a standard GU10 downlight? :sad3:
