BigSim
Hi guys.
Came accross this issue and wondered if anybody else has experienced anything similar. Installed a new lighting circuit in some outbuildings and the customer supplied a little 10w LED flood light for one of them. Completed the installation and when the testing was complete energised the circuit. Turned the light switch on and the LED light came on (so far so good), but when I turned the switch off, the light started pulsing once every 3 seconds?
The light switch was IP rated with a location neon that would illuminate when the switch was off. The only thing that I could think off was that this was allowing enough current to flow to the LED driver (through the lit neon), but not enough to 'strike'. I've also had the same effect when a customer installed a replacement LED lamp, where the same switch was installed.
Installed a 30w LED flood light in another building, and it works fine (including turning off!). There were no other loads connected at the time just a bog-standard radial lighting circuit wired in SWA and surface clipped. It just seems to happen with low wattage LED lights/lamps.
