LED Lighting question. | on ElectriciansForums
Discuss LED Lighting question. in the Lighting Forum area at ElectriciansForums.net
Cincinnati, Ohio
I have built some signs for a customer. They are trimmed with LED perimeter rope lighting which is 110V directly plugged to an outlet (no transformer). The plug comes with two 8A fuses.
The problem is that the supplied plug and cord will be extending from the wall behind the sign too far, so that even with a standard recessed outlet, the cord will push the sign out from the wall.
Questions:
1. Do you think it is a problem to remove the supplied plug and either replace it with a non fused right angle plug, or to eliminate the plug and hard wire the lights to the supply?
2. Do you know of any extra deep recessed outlet configurations that may help?
[ElectriciansForums.net] LED Lighting question.
Reply to LED Lighting question. in the Lighting Forum area at ElectriciansForums.net
My experience with commercial lighting is when the fixture is ordered or bought the specs should say 120/277. Then their wiring diagram should be...
The lights are on a circuit with other lights, which is a different circuit from this receptacle. Both of these circuits and others are on the...
