jacobbetts32
I recently installed some led recessed lights in my living room ceiling. I wired it in parallel with an existing feature in an attempt to make the switches work for the new lights. I have 8 LED lights wired in series coming directly from the source and going directly into the first switch. The lighting ties into a 3 switches(2 3 ways and a 4 way). For some reason when I try to turn the lights off with the switch it is setting off the breaker(20Amp). If I turn the switch back on I can close the breaker in but if I have the lights turned off from any of the switches and I try to close the breaker back in it immediately trips the breaker. Also, before I installed the new lights the fan was tied into the switches in the same configuration and they worked fine. Any ideas what would cause this?
I've attached a diagram showing how I wired the lights as well as one showing I wired the switches. Thanks for your help.
