LED lights blowing? | on ElectriciansForums
Discuss LED lights blowing? in the UK Electrical Forum area at ElectriciansForums.net
J
jjrules2
I have wired 9 LED lights in a utility room. I wired a 1.5mm cable from the CCU to the 1G switch and then took another 1.5mm from the switch in a radial formation to each of the 9 lights ending with just one cable at the 9th light.
I wired these in a week before the builders put the ceiling up (then marked out my cut outs, cut out and pulled the cable through) and I think maybe the builders have nicked a cable, but wouldn't mind a second opinion. When turning the lights on and off, occasionally all lights go on and off as you'd expect, but every now and then 1 or 2, or even 5 in one go, lamps blow!
At first I thought it must be a loose connection and either a live or neutral is not properly terminated, but after thorough investigation this doesn't seem to be the case. I still have 230v at my "end of line" between L-N and L-E and 0v between N-E, so a loose connection can't be the case can it?
Just wondering what you guys think? Don't want to take down all the lights and wack the old tester out and do IR readings between each leg to discover which leg is nicked unless completely necessary...massive hassle and time consuming!
JJ
take the lamps out anf IR test. if you've used 12V LEDs rather than GU10s, more fool you: you'll need to dis. the trannys/drivers.
incompatible drivers might be the problem. hate to say it, but the builders might not be at fault for once. ( any plumbing pipes within 20 ft.? ).
A fiver says they're cheapy-nasty LED bulbs. OP, are there any signs of soot/blackening anywhere on the lamps themselves? Daz
Reply to LED lights blowing? in the UK Electrical Forum area at ElectriciansForums.net
😄 It wasn't the worst I seen over the weekend. Took the kids to Cumbria zoo whilst over there, and the toilets by the giraffes just had twin...
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
