Led Lights Lit Dim While Switched Off | on ElectriciansForums
Discuss Led Lights Lit Dim While Switched Off in the Lighting Forum area at ElectriciansForums.net
K
Karl Andrew
Hello everybody
i came across a nice fault/problem today, I changed some GU10 lamps for the LED kind and they are lit dim while switched off. I have installed 2 new circuits These are the circuits the LEDs are on (1 in a extension and 1 up stairs in the older part of the house) I know these circuits are sound. There is 1 other lighting circuit in the house which I haven't touched yet. And when I disconnect the neutral on the older circuit the LEDs go out.
There is one set of LED lights in the bathroom on the extension circuit that stops on and the other set of LEDs are on the up stairs lighting circuit ( so both different circuits)
in all the other rooms I have used the same LEDs and had no problem
also the affected lights are the last group on the lighting circuit. The house is RCD protected too
any help would be spot on
Had this problem before...
carry out a voltage test at the fitting and I bet there is an induced voltage there. Don't use your continuity testers, use an actual mega tester.
Are they switched 2way?
because they're a weird DC lamp any voltage present will interfere with them.
Michael
One of the groups of lights is 1 way and the other is a 2 way
how would I get round this problem would it be worth rewiring the older circuit
Nope. You will always have induced voltage on a 3 core and earth. It's very minute but enough to interfere with the LEDS.
Unless someone on here knows a way of minimising induced voltage...
its the permanent live in the 3 core laying next to the switch lives... Un avoidable my friend.
the leds I had problems with eventually went after 3secs. Very bizarre
michael
Ring CEF they now carry an LED lamp that will remove the issue for you so just a straight swap :)
You only need to change 1 of them btw
Reply to Led Lights Lit Dim While Switched Off in the Lighting Forum area at ElectriciansForums.net
Indoors? Is the rcbo dedicated to this, or is it an up or down lights rcbo? 6A? Or something else? I'm a bit surprised if it's a current surge...
Loose neutral somewhere… possibly at panel or at the last light before it goes to panel. You say you’re getting power through the switch and up...
