LED Lights | on ElectriciansForums
Discuss LED Lights in the Australia area at ElectriciansForums.net
DurhamSparky
got 48 8ft fluorescent fittings to replace and im looking to make an environmental impact on teh building by using LED lights..!
does any body know who makes 6ft strip lights (full unit) for direct replacement.!!
been abusing Google all morning!
I would not expect manufacturers to make an LED fitting since you can just replace the lamp with an LED one.
The LED fittings coming out are more suited to the use of LEDs and tend to be large surface area.
Buy a cheap standard fitting and fit new LED lamps or just buy 8ft/6ft replacement tubes, there's even some that do not need the control gear removing.
Reply to LED Lights in the Australia area at ElectriciansForums.net
Here are photos of the power supply unit, somebody told me I need a new transformer? Many thanks in advance.
Thank you for your quick and excellent response - I hadn't thought about the cables changing over time. I'll replace all three. Thank you once...
