depends on if you want something basic that is suseptable to false activations or not.combined 500w pir floodlights about £10 but they activate i windy conditions.GjD tolerate windy conditions and have pulse counts to eliminate movement of cats for example.The gjd systems i installed for a security company were very reliable with huge range but they were very expensive,i think just over £200 a sensor.They are 12vcd and have there own powersupply interfaced with a relay controller to activate the flood lights.Would recommend gjd if youre covering an area larger than a tennis court.most electrical wholesalers sell the cheap version of which no particular brand springs to mind.there much the same.only further advice i can give is use 300w lamps.they last so much longer.
