Recently fitted a Saxby dimmable driver and a GE brand dimmable 7watt LED lamp. When I turn the switch on, the lamp does not illuminate, but if I remove the lamp and re-insert it into the lamp holder It illuminates. When I try to dim it, the dimmable lamp just goes out and will not switch back on until I remove the lamp and re-insert it.
I thought it was a poor connection in the lamp holder initially, so I replaced it with a new one. Problem still exists.
I have removed the dimmer and fitted a normal switch, but the problem is still there.
I then tried a non dimmable lamp and it turns on and off without any problems.
Do you think this is just a case of the dimmable lamp not being compatible with the driver?
