tangodownNZ
Hi, I am just wondering if you can please help me.
I have four LEDs connected to a 9 volt battery. They have little circuit boards in them. They will run between 9 volts and 15 volts.
I have them wired up in parallel to a 9 volt battery. They work fine. They are drawing 30mA at 9 volts. So I think that is 0.27 watts. I can’t get the resistor calculators to work because they ask for supply voltage and forward voltage and the forward voltage must be lower than the supply voltage. But I am supplying 9 volts and the led is using 9 volts, but when I type in Vs = 9 and Vf = 9 I get a null answer,
My question is I want to make them dimmer using a resistor but I don't know what resistor to put on them. I was thinking just one resistor soldered onto the positive wire just before the battery.
This is where it gets confusing because I read somewhere that if I decrease the current I will decrease the voltage, but I think these need a minimum of 9 volts to run. Can somebody please tell me if I can use a resistor to do this, and what size resistor I need please.
I was looking at .25 watt resistors but I don't know how many ohms, I would just be guessing. They are currently drawing 30mA so I would like to get that down to around 15 - 20mA
Here they are Little Dot SMD LED Accent Light - 30 Lumens | Super Bright LEDs - Little Dot SMD LED Accent Light - 30 Lumens | Super Bright LEDs - https://www.superbrightleds.com/moreinfo/led-wired-bolts/little-dot-smd-led-accent-light/639/1928/
