G
gerry1234
sorry to interrupt but cannot seem to figure how to send to recipients-can any body re-direct this post
installing led rgb wall washers and unsure as to cable required
can i use 0.75 4 core flex to run 5 led washers @each unit is 54 watt and 2.3 amp /supply is from 24 volt 320 watt supply
or do i require 1.5 4 core flex
18 metres to first unit an then 2 metres daisy chain after to rest
