LED spot lights flickering @ | on ElectriciansForums
Discuss LED spot lights flickering @ in the UK Electrical Forum area at ElectriciansForums.net
V
vinny electric
hi i done a job a few weeks ago where i changed all gu10 50 watt spot lights in a house to LED 3 watt spot lights,i done this for energy savings for the customer...
but this is the thing i got a call from the customer to say when she turns on the bathroom light which is a 2d fitting the lights in one of the rooms closest to the bathroom flicker on for a second even when this light is off. as far as i can see they share a common neutral is this down to when the d2 fitting is first turned on it is pulling a heavy current which is causing a little back feed on the neutral and the new bulbs are only 3 watts they are picking this up. which when the old bulbs where in they where 50 watts so problem did not show its self. this is all i can come up with any and all comments are greatly welcome.
Reply to LED spot lights flickering @ in the UK Electrical Forum area at ElectriciansForums.net
Not to mention welding switch contacts together and wondering why when they thought they had got the wiring sussed the light will still not switch...
Maybe, maybe not. Many electricians do not have a power quality analyser, if you do call one, make sure they have it before paying for a service...
