Hi Guys
looking to put some chrome LED spotlights in a kitchen, obviously they need to be fire rated.
Need about 10 lights, just wondered if anyone could recommend any. Also, iknow some led's don't give off much light can anyone recommend a certain bulb that is good and bright.
Cheers
Craig
anything 4watts and over, but most LED spots are a very "cold" light and mr. client may not like them. i suggest you get a couple of different ones ( warm white, cool white) on sale or return, see what the punter thinks of them.
Have installed Aurora fire rated ones, come with a 6watt warm white or cool white lamp which were pretty good for an LED, suppose to be the equivilant of 50w... but still cant beat a good old 50w GU10.
Might want to suggest they go for some pelmet lights also as a bit of supplemantry lighting...
Dont go for wilts plus range as I first did trying to save ££, they do one, JCC rebadged with a Megaman lamp - crap, ended up taking the lot out...
All the best,
Sy
seen some at electric center. complete fitting £38. guaranteed about 7 years. if it goes down you replace the whole fitting.
Hi ,
Just fitted a load of Halers. Excellent results, 3 LED (7.9W) giving equivalent to 50W halogen, and straight to mains connection.
Come in warm or cool white and a version that is dimmable as well.
Tad pricey though about £40 each for the non dimmable and add about £12 a unit for dimmable.
Cheers,
Lofty.
i get complete fittings for that much
Aye halers are the best for output I have come across c,w driver attached
Just fitted a load of philips led stuff in a commercial job Inc down lights mega pricy but quality tackle tho
Hi,
FYI. The Halers are complete fittings. Just cut a 60-70mm hole and connect the supplied 2 core tails, yep they are class 2 rated, to the mains and job's a good 'un.
Fitted a load, 100+ in a residential complex and all the house managers loved them.
If you're replacing really old downlights they do converter plates as well.
Cheers,
Lofty.
I used regular GU10 downloghters with the fireproof sheilds on then the Phillips GU10 7watt 'warm white' lamp. I thought they were brighter then the GU10s! Phillips reckon they will pay for themselves in a year if they are used for 35 hours a week in energy saving alone!
I've just had a call from a guy I replaced about 25 lv lamps for , for gu10 led in august .He has replaced 4 already and there are another 2 out .quite rightly hes asked me to replace them but he wants the lv back and i'vedumped all the transformers so its gona cost me.told him i'll replace all lamps and try again but either way i aint gona get paid and if the led dont last i will have to replace them with lv.
just letting every1 know as i sold them to him as a way to save money and stop having to replace those lv lamps and its backfired bigtime.I still like led tho.
Hi
I have been buying really good led lamps from a website called www.homewatt.co.uk. They have many different types, but the best ones are the smd type which do look a bit different from most makes available in the wholesalers as there are twenty or so tiny leds surface mounted with no glass lense, but have a resin seal. They are only available via the website, but the 5W gu10 or mr16 are exact same size as the standard ones, and produce a warm light. i cant recommend them enough as ive tried loads of other types and these are by far the best. £20 each though.
cheers
Just wondering what make of LED lamp that would be.....?
Thanku,
Sy
Halers for me just superb for bathrooms as they are IP rated if im not miskaen the halers are made by Stratus lighting or they are part of the same group
Hi,
take a look at yourwelcome.co.uk their range is growing all the time, speak to them as they have a brand new range of LED's coming out.
And no I don't work for them, just find them really helpful and very good quality...
Hi,
As per Nick's post. The Halers for me as well plus they come with a 7 year no quibble warranty, though not had to use it yet !!.
got some Halers to swap out would you believe as cust say's too bright so going for the Halers dimmable version, will work on any 'standard' dimmer.
Cheers,
Lofty.
CEF says it all, i would never buy any of their own brand stuff in a million years ,Everything they sell is Garbage, centaur ,proteus, Itec
Doncaster cables .
Take the lot back to CEF , throw them at them and demand they supply you with replacements of a higher quality OR pay for your time and materials to replace them all with the Low voltage they had before.
Nick
Halers 7w led GU10 lamps are made by philips (it says on the actual lamps). Are these lamps the same as the all in one unit halers or do they give less light?
Got a big job coming up and they want led downlighters all over. Wheres the cheapest place to get them
Ill be honest mate when you look at the cost of the fire rated fitting then the lamp you would have bought a all in one halers they are £45.00 inc vat from senet , and on top of that you get a 7 year extended warrenty , they are top notch ,they come with a short length of flex so easy to install , for led lights i wont use anything else Halers > Home
Your right nickblake, thats what i was thinking. Cheapest place i seen is £40 inc VAT. A normal firerated light with lamp might cost you half as much but you will have to buy more lamps in the future and pay more electricity bills. So its actually cheaper for you in the long run to have the halers even if they cost you twice as much.
Halers website also have a calculator that works out the savings. You just put in the price of the gu10 lamps you can get them for and the price you get the halers for. Then put in how many hours per day you will use them it will tell you exactly how much you save.
Liverpool
Led spotlights
Electrical Tools and Products
hoppy,
saabuldin,
