plugsandsparks
Hi Sparkies, I have been asked to improve lighting in a hall stairway. Its an unusual layout as there are other properties (flats) on either side of the stairs. The stairs run from the front door up to the first floor flat.
I can make some improvements to the ceiling lighting reasonably easily but the client has asked for LED tread lights. Its the ones that normally fit in the stringers on every step. there are 14 steps.
Looking on the internet tends to show quite bulky ones that need a large area behind the flush mounted LED.
Does anyone know of any good suppliers that do the very small LEDS that have an equally small profile back into the plasterboard as there are no stringers on these stairs, its plasterboard both sides (depth unknown)
Appreciate any help
thx
Just wondering, is it the freeholder asking you to do the work?
They might not be happy to be paying for extra juice, however, I shall watch this thread as have been thinking of doing it at home!!
Now these look good!!
DIY LED Steps: Motion-Sensing Staircase Illuminates Itself | Designs & Ideas on Dornob
Yep - thats the concept, but smaller and i need the design sheets to see if ther can be fitted.
Agree its (almost) a nightmare job - wont truly be able to determine likely sleep until i drill the first hole and hope i dont end up next door.
Its not a communal area, each flat is freehold and has its own front door.
dont get me wrong i did not suggest this solution, but its a lovely flat a little avant-garde and the LED lighting would not look out of place, especially a nice blue colour
There are some very thin LED plinth lights about that may be suitable, but it does depend on the lighting effect you want; are you trying to illuminate the staircase, light the treads or accent the treads.
On a quick google I found some that were 6mm deep or ones with a 10mm recess or one that fit in a 35mm back box.
The other alternative is to use flat surface mounted one, people very rarely step on the very edges of the treads and you would then only need space for a cable, and if you do not have that then you would have to go for one mounted in the risers!
If you are looking just to accent the treads if it is dingy then you may be able to use LED strip light as this is very thin, but you would need to choose one that looks OK as most of them are not best placed for direct observation.
The links I found for low profile plinth lights were these, i can't recommend any of them, just a google search.
Moat Farm Trading Ltd Ultra Low Profile LED
Firstlight Lighting 6078SS LED Floor Set Lights - 6078SS
LED Lights - LED Plinth Lights with Integral Driver (White) - Frank Russell
Circular LED Spotlight Kit (3 Pack) : LED Lighting : Maplin Electronics
plugsandsparks
Chesterfield
United Kingdom
Electrical Engineer (Qualified)
LED Stair lights -help with products
plugsandsparks,
plugsandsparks,
