LED Strip in back of van | on ElectriciansForums
Discuss LED Strip in back of van in the UK Electrical Forum area at ElectriciansForums.net
mattg4321
V.Nearly Esteemed
South East UK
Had some LED strip (tape) left over from a recent job so thought I'd put it in the back of the van as the lighting in there is frankly awful.
Connected it up to the lamp terminals so it would work when the doors open and on permanently with the switch as per the original lighting.
All works fine except when you shut the door the light dims down to maybe 10% brightness instead of going off. I measured 6v with the doors shut (the old incandescent lamps go out completely).
Anyone have any ideas how I can get this working properly - I'm worried about it running the battery flat if the lights are on all the time. Maybe it can't be done and I'll have to rig up a separate switch for the LED strip and remember to turn it off.
Cheers
Reply to LED Strip in back of van in the UK Electrical Forum area at ElectriciansForums.net
Thanks davesparks. Looking at the diagram on the driver that's what I interpreted too, but I heard somewhere that the DALI system doesn't like...
Back to the Men's Shed today to complete the installation of the 4 LED battens in the attic. These were a joy to fit, having screwed the units to...
