Led strip lighting issues | on ElectriciansForums
Discuss Led strip lighting issues in the Australia area at ElectriciansForums.net
sunshine coast
Hi all.
I just wanted to see if anyone has had issues with Fans on the same lighting Cct as LED strip lights. I have a job where the fan mech on the
the next switch down on the same light Cct turns a LED strip on and off when running through the Fan speeds. Its not a switched active and the fan and strip have not been wired together accidently these avenues have been explored
Any help or advise greatly appreciated
Hi all.
What I have found is that when the fan is wired in 3 core and earth the permanent live induces a small voltage on the switched live this "charges up" the led which when the voltage is high enough makes the LED flash. I think it is this discharge that has just enough power to kick - in the timer on the fan.
In UK you can buy a "resistive load" which will deal with this induced voltage. It is sometimes called a snubber. (Trade name "Danlers Resload". You can also fit an incandescent lamp but this defeats the object of having LED !
Reply to Led strip lighting issues in the Australia area at ElectriciansForums.net
Hi all, I have a couple of questions I'm hoping you can help with. I have put a solar panel on my kids play house which charges a 12v battery. I...
I have three 6" LED wafers and a ceiling fan on the same circuit/switch. I wanted to control them separately, so I installed GOVEE smart lights...
