Good morning all,
Hope you’re weekend is good so far.
Little question on some LED strip?? I’ve never worked with LED strip before so not really too sure on the ways it can be installed..
I’m re do our bathroom and building a little shelf within the wall and thought I’d see about putting an LED strip within it, to control it I’d ideally like to use a quinetic switch but I’m not sure if a dimmable quinetic switch, connected to a LED driver and then the strip would work?
Does the dimmable driver control the dimming or does it just allow the dimming to be controlled via a switch?
Also, are the LED profiles IP rated or does the LED strip have the be IP65?
Looking on CEF and they only have 2 IP65 and both aren’t what we are looking for so wondered if we would be able to meet the IP rating with the profile.
Thank you
Thank you
