Led strips | on ElectriciansForums
Discuss Led strips in the UK Electrical Forum area at ElectriciansForums.net
schoe
Just a quick one I'm looking to install these in a kitchen under some units, I want to wire them using a switch on the wall, however every website I've seen shows them wired with a plug, is it possible to wire them using conventional wiring or do they have to have a plug on them?
thanks chris
Thanks huntos, how did you wire them up? Did u run power into the driver then take the switch wire out of the driver as well? Thanks chris
Switch wire and neutral to the driver, then you buy fly leads which push onto the led strips and conect into the driver, your local wholesalers should be able to help, I bought it all as one kit but I had a lot to install so may not be the cheapest option for a few in a kitchen
Reply to Led strips in the UK Electrical Forum area at ElectriciansForums.net
The company Liteplan do replacement modules: Liteplan – The UK's largest emergency lighting component supplier. - https://www.liteplan.com/ This...
