LED Tape fault help | on ElectriciansForums
Discuss LED Tape fault help in the UK Electrical Forum area at ElectriciansForums.net
glasgow
Hi Can anyone enlighten me of what has caused this (see attachment ) ? I'm Thinking water but hoping its not so I can take the tape back
  • [ElectriciansForums.net] LED Tape fault help
One series string of LEDs is dead. There is a break either in one of the copper tracks, or a solder joint, or perhaps one of the current limiting resistors is cracked. Water ingress / impact damage / too much flexing during installation would be likely causes, or it could just be a random failure.
Reply to LED Tape fault help in the UK Electrical Forum area at ElectriciansForums.net
Thank you so much for your help with this light work perfect now thank you again much appreciated
If you google '4nway led driver' youshould find something suitable. As mentioned make sure the driver is rated higher than the wattage of tape...
